Saltar al contenido principal
Why did applications stop opening on my Acer Spin 5?
Downloaded applications such as Kakaotalk and Discord suddenly stopped opening up when I double click / run it as an administrator. These apps were running without problems a couple days ago. I have not made any updates or changes to my laptop.
When I double-click on the applications, the cursor wheel spins and then stops, but no application is opened.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario:
i want to install Microsoft office and it requests a product key
what can I do ?
- de
Agregar un comentario
1 Respuesta
Kill the Discord task
  1. Press Windows key + R.
  2. Type cmd and then click OK.
  3. In the cmd window that appears type taskkill /F /IM discord.exe.
  4. After the process finishes, relaunch Discord.
Now everything should work fine. Additionally, you can do the same thing by using Task Manager: press Ctrl + Alt + Del > select Task Manager > in Task Manager find Discord > click on it > click End Task > relaunch Discord.
Does Discord keep freezing? Here’s how to fix it permanently
2: Clear AppData and LocalAppData
  1. Close Discord using the solution above.
  2. Press Windows key + R and type %appdata%. Then hit Enter.
  3. In the new window that appears, find Discord folder and delete it.
  4. Relaunch Discord.
You can also stop Opening discord at starting this will make a fresh open every time, So that you won’t face those issues.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Dana Hong estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 210
