Why is there gas spraying into the tube that leads to my air filter?
There is a small black hose that leads to the tube my air filter is in & the other end is on a cyndrilical metal like item...something to do with fuel I'm guessing. Gasoline comes out the end that goes into the tube that leads to my air filter, my car popped & started smoking the other day after I tried to start it, I took the air filter out, the small black hose off & plugged it up...help! What is the metal cylinder shaped item that the other end of the hose i's hooked up to called?
Thank you.
Es esta una buena pregunta?
1 comentario
@bsrigamarowe post some good pictures of what you are looking at with your question. That will allow us to see what you see. Use this guide Agregar imágenes a una pregunta existente for that.
What exact year is it and hat engine size does it have?
- de oldturkey03
