Saltar al contenido principal
Guías de reparación para el controlador de juego Saitek X52 Pro HOTAS (hands-on throttle and stick). El controlador fue lanzado por Saitek.
Throttle buttons stop responding in certain positions
My X52 pro acts up in certain throttle positions.
the rotator axis will change and loose accuracy in certain positions with the throttle Axis and some of the buttsons stop working as well. I believe it may be an issue with its internal potentiometers but I'm not entirely sure.
And to add to this I've owned this X52Pro for about two years now.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
I AM PHOENIX that will depend which buttons etc. I suggest that you disassemble it using this guide Saitek X52 Pro Disassembly and take a look at anything that may cause a mechanical reason for it binding. If there is none you will have to consider replacing the pots. This video might help you with that task.
Fue útil esta respuesta?
Puntuación 1
4 comentarios:
Thanks I'll try it out.
- de
Also to be more specific it's the center button next to the throttle slider and it's also affecting the throttle hat.
- de
Ok i took a look and all it shows is the main stick disassembly. The isssue is with the throttle. This issue doesn't affect the main joystick.
- de
Sorry about that. Take a look at the throttle detent mods on here. It will show you how to get into and inspect it
- de
Añadir tu respuesta
I AM PHOENIX estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 18
Todo El Tiempo: 751
