Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Un procesador de alimentos compacto con un raspador de tazón interno fabricado por primera vez en 2012.
Lid refuses to come off and when plugged in there is no sound
I got this as a gift 2 months ago. I set up the processor based on the instructions then plugged it in...the processor did not work at all.
Now I am trying to pull down the machine and the LID is stuck and will not move even though I have tried turning it both clockwise and anti-clockwise.
PLEASE HELP
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Sometimes those bowls can be put on in the wrong position, in which case the safety switch will prevent it from operating. Check manual and compare the position of handle with your unit. If it doesn't match, that is the problem. Some extra force might be required to remove bowl that is put on in the wrong position.
Fue útil esta respuesta?
Puntuación 1
1 comentario:
It is not the BOWL that cannot be removed - it is the LID
- de
Añadir tu respuesta
Shorna-Kaye Edwards estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 60
Todo El Tiempo: 4,994
