Why does the power cut off as soon as I turn on the unit
Power issue with Sony Radio CD player and cassette player CFD-S05
unit is plugged in and I have a second unit that works with the power cord.
Es esta una buena pregunta?
Please check whether your symptom matches The Sony CFD-S05 unit will not power up . I added a detailed answer how I fixed the device there.
Fue útil esta respuesta?
I have The Sony CFD-SO5 and so how did you go from switched to unswitched ? Did you have to tear the unit apart ? How do you bypass the On/Off button ?
I did take the unit apart. @oldturkey03 posted a link to the Service Manual. It explains how to take the unit apart. In my unit, the problem was *not* with the power switch, so bypassing either that button or the electronic switch controlled by it would have made everything worse. The actual problem is a short circuit on the main board. You have to fix that. The unit performs a kind of "self-test" every time you try to turn it on, and automatically turns off again if there is a short circuit.
Edward Walker you need to take a look at the power supply. Most likely a capacitor or transformer issue. Disassemble your unit CFD-S05 Disassembly and post some images of the power board so we can see what you see. Here is the guide for that Agregar imágenes a una pregunta existente
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 66
Todo El Tiempo: 4,349
1 comentario
Great, i changed the capacitor and ifixit !
- de Michel Beaulieu
