Saltar al contenido principal
What can I upgrade to make this laptop faster?
What are possible upgrades to make my Laptop work a whole lot better? Thank you
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
Ok. Yes, an SSD can greatly improve the speed of your system. RAM can too. But everything in moderation.
So here are the doctors orders:
  • If you need space but speed, I recommend you remove your optical drive, put you old HDD in there and put an SSD in the HDD's place.
  • If all you need is speed, simply replace the HDD with an SSD.
  • If you don't want to sacrifice your optical drive, but need plenty of space, you can either get an SSHD (a small amount of SSD combined with a HDD) or just a large but expensive SSD.
Got a that? Good. Now onto the RAM.
  • Most people don't use more than 8GB of RAM. If your laptop doesn't already have this, this can also greatly help.
  • If your computer has a single 4GB stick, get another 4GB stick to compliment this. If it has any other size less then 8GB replace it with a single 8GB stick.
  • If you really need 16GB, get two eight gigabyte sticks.
If you upgrade to an SSD or SSHD, you'll have to re-install Windows. Use this link to make a bootable thumb drive: https://support.microsoft.com/en-us/help...
For all your needs, Dell provides repair manuals. I got the one you need right here:
Inspiron 15 3000 Service Manual
Hope this helps! If you confused about all this, just tell me how much storage you need and what you'll be doing. I will also recommend parts once you've made a decision.
Fue útil esta respuesta?
Puntuación 4
4 comentarios:
Thank you very much for that. I'll rate but don't know how. Tell me how for I to rate you
- de
@reaperxcelerate, you already did by accepting my answer and upvoting it. Thank you!
- de
Any idea of the current configuration of ram? Is there only one slot? And there is one 4gb ram in there. Or is there 2 slots with one 4 gb ram that I can either add one 4 gb ram to make it a total of 8 ram or add 8 ram to a total of 12 gb?
- de
Hi @ fardi yeung,
According to the specifications the laptop supports up to 16GB DDR4 2133 RAM over 2 SODIMM slots using either 2GB, 4GB or 8GB modules. See p.13-14
So you can have 12Gb made up of 4 + 8. (ensure that they are of the same speed etc)
- de
Upgrade the hard drive to SSD, that is the best upgrade you can make.
Puntuación 2
3 comentarios:
What else can I do? I know I'm able to upgrade the ram to 16GB. What about the graphics card? CPU? Processor?
- de
Ram and SSD Upgrades are the only replaceable parts on this machine. Most laptops have the GPU and CPU Soldered to the Mother Board
- de
That's it? Nothing else?
- de
Añadir tu respuesta
Ryan Montesino estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 5,133
