iPad 4 Broken Screen issue
Can someone tell me what part I need to repair this?
Es esta una buena pregunta?
The front glass is the digitizer it's usually a single piece bonded together lens and digi together behind that is the lcd... if it's already cracked or scratched you might as well change the digi anyway
Fue útil esta respuesta?
Thanks for your help!
U seem to need the lcd and you might as well order a digitizer as well in case you break it when your trying to remove it.
So they sell the LCD, which is apparently behind the glass. So I need to order the front panel, the LCD, and the digitizer. Correct?
The front glass is cracked.
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 93
