Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Apple lanzó el iPad Air adelgazado y pulido el 1 de noviembre de 2013 en una opción de Space Grey o Silver. Incluye el procesador A7 personalizado y se envía en configuraciones de 16, 32, 64 y 128 GB.
iPad Air Charging issue...
When hooked up my iPad Air does not show a charging symbol. Im not sure if the battery is dead or if the charging port is malfunctioning. How could I know to order the correct parts? There has been no previous damage to the iPad.
Thanks,
Andy
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
That is the conundrum DIY fixers face. If you haven't already done so, open up your iPad. The battery is usually the part that needs replacing. Still, once you have removed it you can probe it with a multimeter to see if it is holding a charge. At ~4.2V, it is pretty much full and at 3.5V it is pretty much empty.
If the battery is holding a decent charge and you're not getting the charging symbol, you may have a defective charge port or logic board issue. If the battery is dead, then it's probably the cause (but it could still be something else). If it looks like a charge port or logic board issue, it will require a micro-soldering repair and is not DIY.
Ultimately, the only way to know is to try known-good or new components.
Fue útil esta respuesta?
Puntuación 3
Añadir tu respuesta
andystills estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 1,717
