Saltar al contenido principal
The third-generation HTC One smartphone which was first released in March 2015. Its major revisions on the M8 design include the octa-core Snapdragon 810 processor and a 20-megapixel rear camera.
Preguntas 71 Ver todo
Why wont my phone turn on?
my phone died today and when wanted to charge it all its says is 0% battery and turns off ... turns on again shows the 0% battery and then turns off .... its been more then 5 hours with my phone doing this ...it hasnt charged at all .... I NEED HELP, PLEASEEE
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
You need to check your charging system . Try a different charger, check the cable and phone port for damage or dirt . If you need to clean the port use 99%ip alcohol and a soft toothbrush . A toothpick may also be helpful . If your port is loose or damaged you will need to replace it . It could also be the battery has reached the end of its duty cycle . This guide shows how to replace the charging port
HTC One M9 Headphone Jack/Micro USB Board Replacement
This guide shows how to replace the battery
Reemplazo de batería de HTC One M9
Hope this helps
Imagen de HTC One M9 Batería
Guía
Dificultad:
Difícil
30 minutes
Imagen de HTC One M9 Headphone Jack/Micro USB Board
Guía
Dificultad:
Difícil
30 - 40 minutes
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
XhenaS estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 106
