My frame around the screen at the bottom corner cracked
Frame at the bottom corner of the screen around the joint when the screen opens and closes cracked
Es esta una buena pregunta?
@cmeyer0922 not quite sure what you are looking at. It sounds like your bezel is cracked. To verify this, post some images of what you are looking at, with your question. Use this guide Agregar imágenes a una pregunta existente for that.
If it is the bezel alone, use this video. Slightly different model same idea.
If it is that the hinges are actually braking the case/frame then you should get this covered under warranty. After all the GE72 should still be pretty new.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 1,265
