Saltar al contenido principal
Why can't I enable the Wi-Fi?
My laptop was working smoothly but suddenly one day after switching on my pc the Wi-Fi option in my toolbar vanished. I tried going to the control panel and connection settings but every time it shows Ethernet and vpn. There is no Wi-Fi Option. What should I do?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
2 comentarios:
What model is the laptop. There are hundreds of dell laptops
- de
Some Dell laptops have a switch to enable or disable the wireless. There should be an indicator light for the wireless, the indicator light should be with the group of Power and Disk indicator lights. If the Wireless light is not lit then check to see if there is a physical switch on the side, usually on the right side. If there is no switch, then there should be a button or key at the top of the keyboard to enable the wireless connection.
- de
Agregar un comentario
1 Respuesta
Things to try:
Open device manager and check if your WiFi adapter shows up, if it does show up but you don't have an option to connect try doing a system restore to a date you know it was working.
Sometimes the driver can malfunction and cause the adapter to stop working if this happens the device will have a yellow triangle next to it in device manager or it will be under unknown devices, in this case just download the driver and reinstall.
If it doesn't show up at all in device manager, then you will need to open the laptop and check the connectors for the WiFi card, if you're not familiar opening a computer you should take it to a repair shop. Worst case scenario you will have to replace the WiFi card or you can buy a USB WiFi dongle.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Shivangi Sarkar estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 48
