120v Nutribullet not working, ran on 220v
Bought a Nutribullet from US and accidentally ran it with 220v supply. Later bought a step down transformer and tried, it's not powering on, what could have gone wrong? Disassembled the unit and the motor windings etc look fine, is there a fuse or a reset?
Update (07/02/2017)
Is there a wiring circuit diagram for Nutribullet? The motor windings are rated 120v, so it would not run on 230v, this would require re-winding of the motor to match the voltage.
Are the power boards sold separately?
Es esta una buena pregunta?
6 comentarios
If afraid it might not be easy, it could be embedded inside the motor winding.
- de Augustine
Please refine your answer. What could be in the motor winding? What's not easy about doing what? Is there a guide to do this?
- de George A.
I was able to disassemble the unit, the thermal fuse is fine, the copper windings look ok, it's not burnt, melted or fused. There is some circuit with couple of transistors, capacitors, resistors and diodes, could something have gone wrong there?
- de chethan anand
Hi Chetahan ananad,
please share that circuit pictures. most probably some components were blown to protect the device.
- de Augustine
Hi @salmonjapan ,
As this was an older question I moved the latest "comment" to a new question so perhaps you'd would care to comment on it there and delete your comment here.
Used without the converter. Now I see or smell some burnt..
Sorry if it caused any confusion ;-)
Cheers
- de jayeff
Mostrar 1 comentario más
