Saltar al contenido principal
A programmable brewing machine by Keurig. This coffee maker uses K-Cup Pods and K-Carafe Pods to brew a variety of hot and cold drinks. Model Number: K2.0-400 Serial Number: 401.0200.1410931
Preguntas 59 Ver todo
Piece of rubber hanging down from needle
My Keurig 2.0 is working but there is this little rubber piece that is hanging off from the top. It is a straight piece that then ends in a little rubber circe. The circle is broken.
My daughter is planning on taking it to college with her in September and I was wondering if I can fix this little piece some how.
Update (06/29/2017)
This is a picture from under my machine
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 3
2 comentarios
Answer is related to the mini-pump, but the question is about the needle seals.
- de
this looks like a black rubber washer. Why can't I find them anywhere?
- de
Agregar un comentario
2 Respuestas
Respuesta Más Útil
This is the seal washer for the needle. I don’t recall why there’s two parts to it. I think mine only has one. It seals between the machine and the top of the pod.
This might work to fix it: https://www.amazon.com/Replacement-Needl...
https://www.bonanza.com/listings/Keurig-...
Fue útil esta respuesta?
Puntuación 3
2 comentarios:
The item from Bonanza should work since my Keurig is a 2.0 K400. The part is a little pricey, but it's cheaper than a new Keurig. I also don't know about the 2nd attached piece, but I guess I will find out! I will order this and keep you posted. Thank you for all your help in locating this part.
- de
@willpsree thanks for posting the link excellent find since those O-rings have a tendency of disappearing!
- de
This guide shows you the tubing:
Keurig 2.0-400 Mini Pump Replacement
Puntuación 1
Añadir tu respuesta
Phyllis Jozwik estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 15
Ultimos 30 días: 75
Todo El Tiempo: 7,699
