Saltar al contenido principal
Modelo A1278 /Procesador 2.4 o 2.66 GHz Core 2 Duo de mediados de 2010
Preguntas 795 Ver todo
bluetooth improvement or upgrade?
hello I have a MBP mid 2010 and ive tried all types of solutions to fix my Bluetooth problems ex. iphone , speakers, etc.Well my question is that if it is possible to change the BT card or any improvement so I can be able to connect my iphone and such devices also it is an LMP: 2.1 (0x4) and is not handoff supported. I recently upgraded my mac, I bought a 16 GB (8GB + 8GB) ram memory, a 480 SSD, and a new battery. my mac is a potencial beast I use it for university works such as autocad civilcad wich are heavy programs and now everything works fast with no lags. I would really like to have a solution to upgrade my bBluetoothproblems. please help. greeting from PERU
Es esta una buena pregunta?
Puntuación 0
1 comentario
I believe that its the antennae cables. @danj Will know the answer to this
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Sadly this series can't be updated ;-{
Unlike the newer models which use a mini PCIe interface in the main case. This model uses a BT/WiFi combo board held within the clutch cover which you can see here:
Even the next gens of the 13" & 15" can't support BT 4.0 internally, you would need to jump to a 13" Retina Late 2012 model or use an external dongle with the newer 2011 & 2012 models.
Fue útil esta respuesta?
Puntuación 3
2 comentarios:
Hello @danj is there any way that I can use an external dongle with my mac? I have read that it is possible but with some special hack patch/program. using an IOGEAR Bluetooth 4.0 USB Micro Adapter. thanks a lot for the hardware help it really helped me. ohh and Are there any disadvantages if I buy the screen of the 13" Retina Late 2012 or wont be compatible?
- de
@juanmalpartida - Can you use an external dongle? It depends on what you are trying to do here. Review this if you are looking for Hand-Off Services. Somethings still won't work Continuity Activation Tool Compatibility Chart as well as read up on things here: Continuity Activation Tool - Web Site
You can't switch the screens between a non-retina to a retina if that is what you are thinking. The newer Retina systems use a very different design for both the display and how the AirPort is connected. Here's an image of the Retina models AirPort card: Retina AirPort. Note its in the main case mounted to the I/O board and the coax cables to the antenna's are fed into the lid though the hollow hinge.
- de
Añadir tu respuesta
juanderola1899 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 8
Todo El Tiempo: 894
