The battery cover is not opening
The battery and sd card cover will not open. It is stuck closed. Can you please advise?
thanks!
Es esta una buena pregunta?
thanks!
@geefamily , GeeFamily, The link below shows how to open battery door. If quite stuck, use a heat gun/hairdryer to heat up around the battery compartment door latch area(carefully heat, not excessive) and then try opening may have to pry a little while sliding/pushing the buttons to open position. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Fue útil esta respuesta?
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 43
Todo El Tiempo: 2,153
