Saltar al contenido principal
Fujifilm FinePix XP50 Battery Replacement
Qué necesitas
  1. Fujifilm FinePix XP50 Battery Replacement, Battery: paso 1, imagen 1 de 3 Fujifilm FinePix XP50 Battery Replacement, Battery: paso 1, imagen 2 de 3 Fujifilm FinePix XP50 Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Slide the lower silver tab labeled "1"down.
    • Slide the upper silver tab labeled "2"down. Once the second tab is flipped, the door will spring open.
  2. Fujifilm FinePix XP50 Battery Replacement: paso 2, imagen 1 de 1
    • Slide small orange tab to release the battery.
  3. Fujifilm FinePix XP50 Battery Replacement: paso 3, imagen 1 de 2 Fujifilm FinePix XP50 Battery Replacement: paso 3, imagen 2 de 2
    • Simply insert the new battery following the black arrow printed on the battery, matching the orange side of the battery to the orange rubber of the inner battery door.
    • The orange tab will automatically move to hold the battery in place upon insertion.
Conclusión
2 personas más completaron esta guía.
Equipo
Baylor, Team 2-4, Grigsby Spring 2015 Miembro de Baylor, Team 2-4, Grigsby Spring 2015
BU-GRIGSBY-S15S2G4
4 Miembros
8 Guías creadas
Un comentario
Hi Catherine,
Could you direct me to where I could buy a replacement battery door for the XP…exactly the same used in your video.
Many Thanks
Robert
robert trott - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 23
Todo El Tiempo: 2,582
