Saltar al contenido principal
Esta versión de la serie Kindle Paperwhite de Amazon se lanzó el 30 de junio de 2015. El Kindle Paperwhite de tercera generación es una tableta con pantalla de lectura de 6 pulgadas y 300 PPP que cuenta con capacidad para Wi-Fi. El número de modelo designado es DP75SDI.
Preguntas 48 Ver todo
Frozen unresponsive screen. Can it be repaired?
Hi!
I have a Kindle Paperwhite, 6" High Resolution Display (300 ppi) with Built-in Light, Wi-Fi - bought in October 2015.
Kept well, it hasn't fallen down, nothing untoward. Stopped working. The screen had an erratic display for a while, and has now stopped responding.
Can anyone help?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 4
1 comentario
I am having the same problem, could you find a solution for this? Please let me know.
- de
Agregar un comentario
3 Respuestas
Respuesta Más Útil
I had this problem with an e-reader and it turned out that it quit charging. After placing the e-reader on a new charger it started working again. The models we use in our school are all nooks but this may help you out too.
Fue útil esta respuesta?
Puntuación 1
1 comentario:
Hey! Thank you so much. But this one is charging. No problems with that. Just that the screen gave an erratic display and then stopped responding. I am trying to understand if it is a screen or motherboard issue. Will try and fix it accordingly.
- de
Did you find a solution to this? I am having a similar problem
Puntuación 0
2 comentarios:
... me too!!!
- de
@skeeve205 could you please let me know if you found a solution for this?
- de
Try tapping (or knocking with your nail) in the bottom right corner of the front. (Edit: you can also try bringing a magnet to that corner and bringing it away)
If it responds, then I have a workaround for this, that I’ll publish as a “technique” guide within the next few days. (EDIT: here it is!) The only problem with that guide is that it will no longer respond when opening/closing the cover
Puntuación 0
Añadir tu respuesta
Anamika Das estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 4,824
