02 Jetta VR6, trouble with hot start
My 2002 Jetta GLX VR6 is having an issue starting but only when the engine is warm and I've been driving at least 20 minutes but sometimes I have be be running it a little longer.
Once the engine is hot enough and I shut off the car, it will act like it isn't getting gas and will act like it might stall out (sometimes it does), when I try to restart it (if the engine hasn't cooled enough). It might take me 3 or 4 tries but I always eventually get I started. I turn the ignition and while it's sputtering, I lightly press the gas. It drives without any problems
I had read it could possibly be a solenoid getting too hot (possibly a heat shield got removed during a repair and didn't get put back?). However, I do not recall what part was possibly overheating. I've been to two separate shops and I had the coolant sensor and the radiator cooling fans replaced but I'm still having the same issue.
Es esta una buena pregunta?
1 comentario
Hi,
Have you had the ODBII port scanned to see if there are any error codes logged?
- de jayeff
