Black wire on control board
I took off the water /ice dispenser control board to clean the dispenser . There's a black wire attached to the board where does the other end go to
Es esta una buena pregunta?
Hi,
This link may be of some help in solving your problem, if you can read a wiring diagram that is.
Fue útil esta respuesta?
It some how got set to floor model/show room mode.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 470
2 comentarios
Missy, add your make, model and model#, was the wire ripped from a connection or is there still a connector on it. this info. will help ifixit volunteers to answer your question more effectively. Good luck.
- de L Pfaff
It's a GE gfe28hmhees french door bottom freezer. The connector and wire are attached to the control board. I have no clue where the other end with a connector goes
- de Missy
