Can the screen be replaced due to being tapped by a baseball cap
Sharp Model LC-32LB37OUThe screen has lines in it and a blackout spot where it was tapped
Es esta una buena pregunta?
naparace55 in theory it is possible to replace the display. However, they are not easy to come by and sometimes they cost more than a new TV. What you want to do is to look at the label on the panel, not the TV and do a search with the panel number. you may find a supplier. If not consider places like ebay, craigslist etc,. See if you can purchase a set that is broken other than the LCD and use that, to harvest the screen from.
Fue útil esta respuesta?
Yes, indeed. All you need to do is bring your mobile to phone shop and get advice.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 36
