Is there anyway to replace the rear case of the iPad Pro 12.9?
So let's say the rear of the ipad got dented, and needs to be replaced.
Is there a part available anywhere for the rear shell?
Es esta una buena pregunta?
@imenace , dam, Just a thought, instead of replacing the back cover at probably considerable expense, maybe remove the back cover (1st link guide to show disassembling)and push the dent out the best you can and if not satisfied cosmetically put a nice wrap on the iPad or hard back case cover. Good luck.
Fue útil esta respuesta?
If available at all you'll find it on ebay, but from a first look I can see only a 9" housing worldwide right now and it's pretty expensive too. It sems you got a difficult task at hand..
Instead of replacing with the original aluminum back shell I’m wondering if it would be possible to use something lighter and stronger such as carbon fibre? If so, do you know where I can find that back shell?
Ultimas 24 horas: 3
Ultimos 7 días: 19
Ultimos 30 días: 69
Todo El Tiempo: 6,681
1 comentario
My IPad Pro has dented back. Apple said trade it in. Unrepairable. Keyboard at times will not register the typing. It will skip a letter or a space. Can this be repair?
- de Ricardo Gallegos
