How many hours am I going to charge this?
I don't know the charging hours for this.
Es esta una buena pregunta?
Hi,
Check the battery status icon on the taskbar. It should give an indication of the remaining charge time.
The time it takes to charge depends on how low the battery was when you first started to charge the battery and also whether the laptop is on at the time and if you are using it as well, which means that it will take longer than if it was switched off and it was just charging.
Fue útil esta respuesta?
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 14
Todo El Tiempo: 138
