htc One m8 got wet. Is damage battery or processor?
Hello.
Should I try a battery replacement, or just forget it?
My wife's htc One m8 got dunked and totally wet with water. (Water intrusion marker strip is completely red/pink).
From what I recall (been a few months now & already bought a replacement), she was at the Dr office, but shortly thereafter (in the car), she put it on the charger. I told her the best thing would have been to power it off, until we dried it. However...
When she got home I got the phone. It was hot and I could barely see the display. I was trying to select Power Off, but it was difficult to see anything on the display. I either turned it off, or it just went off by itself.
I took the case back off it, peeled back the foil tape, pulled off all the connectors, and did my best to totally dry it. I stopped short of lifting up the motherboard.
After 24+ hours in rice and disassembled I put it all back together and tried to power it on. Nothing. I tried all combinations of Power button, Vol up and Vol dwn. No indication that it was trying to turn on, whether on the charger or not.
When it is on the charger the indicator LED is orange (solid), but after a lot of time on the charger it will not power on, the LED never goes green, and it seems like a little warmth on the body when charging, but not really sure.
As a replacement battery is about $20, I thought this may be worth a try, unless the indication is that the motherboard got fried.
Connecting the phone to a computer, the pc does not see the device. However, it will not power on, so this may not mean anything.
Any suggestions on what I should do? Thanks.
BP
Es esta una buena pregunta?
1 comentario
Thanks.
I believe I will try better cleaning and a new battery. I did not notice any debris or mineral residue on anything, but that does not mean it is not there.
Water gets in places easily, and is very difficult to get out if air cannot get at it.
Something I failed to mention in OP, there is a small piece of a board (possibly part of the IR emitter?), near the power button at the top that I either broke on initial disasembly, or was either already broken. A tiny square, perhaps 1 or 2mm square, and what looks like a tiny, tiny cable or flat ribbon which looks like it came unglued or detached from the board where it lays. I know it is hard to imagine what I mean, or "troubleshoot-over-the-phone" with what I am describing. I can take pics, if it helps.
I didn't want to spend $$ on a battery if someone had this exact experience and found that there was some way to know that the damage is in the motherboard or daughterboard, and not the battery, given that the phone does not power on.
Thanks.
BP
- de Barry Paulus
