Why is my freezer intermittently working?
Last night, we noticed a puddle had formed in front of our side by side
refrigerator. We opened it up to find everything was defrosting. The fridge initially seemed unaffected, but after several hours also began to lose its temp. The fan inside the freezer blew foolish air, far from cold.
I pulled it out of the recessed area it's pushed into, took the cardboard panel off the back and found a thick layer of dust on the circular fan that blows on the compressor. I vacuumed all the dust and basically anything I could get at, along with suctioning the drainage tube to clear any blockages. Heard no clicking noises. It all still worked and ran, just no cold air.
On a side note, I looked for the radiator grating, the tubes that circulate the refrigerant, and it seems like they're incorporated into the fan, at least I could see it just underneath and possibly inside the fan. Don't know for sure.
I cleaned off the cardboard and the two vents placed inside the recessed area, there for air circulation. I also looked behind some panels to see if any plugs/connectors were burnt. Found none and made sure all plugs were secure. I then put it all back together.
It seemed to have no effect, I left the fridge out of its cave overnight and went to bed. I woke up this morning and it was working again. The fridge is cold, but the freezer might not be working at full capacity. The ice packs have yet to become rock solid again.
What are these issues indicative of? How did my freezer regain at least 75 to 80 percent of its capacity? I was hoping the particulars of my problem might narrow the scope of possible solutions.
Its a GE model GSH22JFXA WW
Thank you for reading through that mess.
Es esta una buena pregunta?
4 comentarios
My stand-alone upright Frigidaire freezer was running all the time. I fixed the seal a day or 2 ago. Today it stopped for 7 minutes, then runs for 3 minutes and keeps cycling in that pattern. Any suggestions?
- de Amber Dash
This also happened to me last night. I am no freezer expert but several days ago my freezer began to struggle. I could hear the fan making a loud noise. Then the fan and freezer completely stopped. I cleaned all the ice out of my freezer and made some space. I could see ice back where the fan was. Looks like this melted in a few hours then the fan and freezer began to work again.
- de byrdbrayn
Hi @byrdbrayn
What is the make and model number of the refrigerator?
Sounds as though there is a problem with the defrost system.
It may be either a faulty defrost heater, a blocked drain from the freezer compartment to the evaporator fan under the compartments, a faulty defrost thermostat or worst case a faulty defrost timer or control board
- de jayeff
My freezer stopped working and then a day or so later it started to work again. It has been working fine ever since. The refrigerator is from 2008 and is a side by side. Now that the freezer is working again - which is now more then a week - I was wondering if I should just keep the unit or get it replaced. It is not making any loud noises and seems to be working just fine,
- de bhoffman528
