Saltar al contenido principal
Lanzado el 19 de septiembre de 2014, este iPhone de pantalla de 5.5" es la versión más grande del iPhone 6.
Preguntas 1526 Ver todo
iPhone 6 Plus sporadically turns off <60% charge, bad battery?
Good afternoon,
I have purchased an iPhone 6 plus on eBay from a reputable seller. The phone was not 100% new but I was advised it was a stock model and in good condition. When I received the phone (without retail packaging) I had no indication to think otherwise, it did not even have a scratch on it.
I've had the phone for about 2 months and a strange issue began to surface. For some reason, when the phone's battery is below 60% and I use it outside to take a picture or watch a youtube video, it completely turns off. The phone will not turn back on unless I plug it into a wall charger. It does not have to plugged in for long, even for ~5 seconds is enough. It's almost like a car with a dead battery that needs another car to help it jump-start.
When the phone turns back on it shows the same battery level as when it died, i.e. is not at 5%. I should also add that this does not happen every single time, but I would say it happens over 50% of the time, which is obviously too much too tolerate.
I read through similar iFixit forum posts about battery issues, so here's my question: does it sound like an old battery issue or a damaged tristar ic (or something else?). The phone came with a brand new and, from what I can tell, genuine Apple charger, although I cannot vouch if a non-apple charger has been used with this phone in the past.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
Most likely battery just needs to be replaced. Try that first because it is the cheapest option.
Fue útil esta respuesta?
Puntuación 3
1 comentario:
Thank you for your reply. Probably a rhetoric question but... The iPhone 6 plus batteries sold on this website are authentic batteries?
- de
Hi there ll be 2 issues
1. Try with changing New Battery
U can Go Through The Link For Genuine Battery
iPhone 6 Plus Battery
2.There ll be issue with U2IC Issue on Board Level or Restore the Device
Hope it Works
Thanks
Varun
Imagen de iPhone 6 Plus Battery
Producto
$29.99
Puntuación 0
Añadir tu respuesta
Jason M estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 260
