lcd screen does not respond on right corner
previous screen this phone works fine, but when my cell phone fell to the floor the lcd screen is not cracked but, the lcd screen is not respond on right corner. i dont know what should i do for this problem to fix my phone, should i change the lcd screen or not? anyone can help solve this problem? thanks before
Es esta una buena pregunta?
7 comentarios
Reseat the screen connections for the screen. If it still does not work then the screen has gone bad (make sure to unplug battery before doing so.)
- de Ben
@benjamen50
i have doing that, unplug and plug it again the lcd connector but i forget to unplug the battery before doing that. whether there will be a problem?
- de Luthfie Rachman
It's recommended you unplug the battery because blowing the backlight circuit is a possibility if it's still plugged in.
Anyway you can conclude the screen has gone bad.
- de Ben
okay thanks @benjamen50 it means I have to replace a new one lcd?
Yes. New screen. LCD is fused with the digitizer.
- de Ben
Mostrar 2 comentarios más
