Tranny stuck in reverse
How to take it out of reverse
Es esta una buena pregunta?
@jpnegron , Sergio Angulo , If manual transmission, try having some one rock the truck back and fourth while you try shifting out of reverse. If it does pop out your clutch/pressure plate/master/slave cylinder may be worn/faulty/ or have air in hydraulic system not allowing release. If it will just not come out of reverse suspect a damage/bent shift fork inside tranny. Good luck.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 263
