Xiaomi Redmi 3x - I developed a charging problem with my Xiaomi because of using a fast-charge cable that apparently wasn’t compatible with the phone and the phone dropped to 0% and just wouldn’t charge.
Please note: If the light below the home button isn’t on (Solid, not blinking), the phone isn’t charging. I left the phone plugged in for 18 hours and it had no effect.
- Remove the back cover (that was quite difficult without the correct tools and I ended up snapping off some of the siding. Would recommend the correct tools and watching a few youtube videos on this.)
- Unclip the battery cable to the main circuit board.
- Plug the phone in, this will cause the screen to come on
- While the Mi-Logo is displayed attach the battery cable again (before the battery percentage displays)
- The phone will enter a charging state for around 2 minutes and then stop charging again.
- Repeat step 2-4 until you’ve got the phone up to around 8% battery (the battery % indicator will fluctuate anywhere between 8-20%)
- Boot up your phone
- While the phone was on I had the charging state fail several times until the phone reached 11%. I just repeatedly plugged it out and back in. After around 11% the phone continued to charge normally.
- Other things to note: One post said to turn the volume up to Max and disable Wifi, I did both
PS: Using a USB cable to PC wasn’t good enough as the small charge provided wasn’t enough to charge the phone to where the screen would turn on properly.
PPS: In some cases the phone went into a loop of screen-on/screen-off. In this case, I disconnected both the battery connector cable and the battery sensor cable and left it to vibrate for a while, connecting and disconnecting the cables while in a “boot” state, seemed to get it out of this state eventually.
PPPS: If the battery connector cable disconnected from the main PCB then the battery percentage will always display 0% even if it’s not the correct charge.
Part of me is afraid that if the phone battery ever hits 10% the problems will occur again, but hopefully it won’t.
I’ve also ordered a new charging circuit PCB on the internet to replace the current one in the phone.
At first I thought it might be the battery that’s the problem, but after reading many posts and realizing that the charging PCB is cheaper than a new battery, I thought I’d give that a try.
Unconfirmed:
Deeper research states that there’s a “zener diode” on the main PCB board that can burn out when your use a charging cable that’s voltage is too high. This can be removed and will allow the phone to charge, but it’s not recommended as the phone’s voltage input won’t be regulated anymore.
Edit: I eventually replaced the charging PCB on the phone when the new one I’d ordered online arrived, which resolved the issue completely.
It’s not terribly difficult, just removing the back cover, unscrewing, unplugging it and screwing in, plugging in the new one.
A new charging PCB is most definitely cheaper than buying a whole new phone.
Please do make sure that you get the right model number though, as it needs to fit perfectly into the phone. The one I bought ended up being slightly off from the original, so the phone case at the back is distended after closing everything up.
22 comentarios
Have you connected the USB cable to a computer or a different charger to see if it charges?
- de S W
Yeah I already did
- de Daniela
open back cover.... open usb charge socket DO short circuit usb SOCKET AND TOUCH A WIRE OR A METAL THING BOTH SIDES BAC OF THE USB CHARGIN PLACE DO IT 2 OR THREE TIMES THEN IT WORKS..... MY TWO PHONES WORKED THE MAIN REASON WHY THEY DONT CHARGE IS USING SOME FAST CHARGING CHARGERS OR POWERBANKS...... DO WHAT I SAID IT WORKS
- de DM - Agar (Melo)
Can you explain how to shortcircuit the charging port?
- de johnny liu
Yes how to do the short circuit thing? Can you explain step by step
- de aus hardyz
Mostrar 17 comentarios más
