Laptop crashes when plugged in
My laptop crashes when I plug in the charger but works without the charger just fine.
It takes some time after the charger is plugged in for it to crash and when it does, I turn it back on and the screen displays "Windows is resuming"
I have attempted to plug in a separate charger and the same result occurs
EDIT: The laptop works perfectly fine when plugged in and on safemode.
Es esta una buena pregunta?
16 comentarios
Hi, Have you checked in Event Viewer, to see if there are any events registered which may indicate your problem?
- de jayeff
Does it show the battery as charging? I would check event viewer and see what shows up there. Your charger may even be shorted so you may want to try a new one or different one
- de Jetlabb
I have no idea what the event viewer is and how to use it, please explain?
- de Andrew Hall
everything in the administrative events says either critical, error or warning.
- de Andrew Hall
"Task Scheduling Error: Continuously busy for more than a second" and "Task Scheduling Error: m->NextScheduledEvent 19594" are the errors that occur while plugged in.
- de Andrew Hall
Mostrar 11 comentarios más
