1990 Range Rover Non-functioning door lock repair
I need step-by-step directions on repairing the malfunctioning door locks on a 1990 Range Rover. Thanks for any help that might be given.
Es esta una buena pregunta?
ronalink, Power door lock actuators replacement page 58 in the Range rover instruction manual below. Good luck.
SYMPTOM POSSIBLE CAUSE CURE
S-Central door locking does not operate (on all doors)
1. Battery discharged/ Recharge
2. Control unit in driver’s door lock actuator faulty/ Fit new unit
3. Loose or broken connection in driver’s door/ Locate and rectify
4. Blown fuse/ Rectify
T-Central door locking does not operate (on one door only)
1. Loose or broken connection/ Locate and rectify
2. Lock actuator failure/ Fit new actuator
3. Faulty lock/ Rectify
4. Mechanical linkages disconnected/ Locate and rectify
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 6
Todo El Tiempo: 131
1 comentario
ronalink all door locks or a particular door? What have you checked thus far?
- de oldturkey03
