Saltar al contenido principal
Mando PS4 modelo CUH-ZCT1. Lanzado en noviembre de 2013 por Sony Computer Entertainment, este controlador de batería de iones de litio de 3,7 V y seis ejes no es complicado de reparar. (NOTA: la guía de desmontaje NO es para este modelo)
The square button is not work
The square button when I press on button is not work what I do
Es esta una buena pregunta?
Puntuación 9
2 comentarios
you can replace the square button. you can order the motherboard from the IFIXIT site. and you can see how to fix also on this site.
- de
Yo no lie all I just did was get some scissors and pull up tried to wedge it in the side and just keep doing that trying to take the square button out than just pull up Spotify and keep trying use square till it work I swear try it
- de
Agregar un comentario
5 Respuestas
Solución Elegida
Hi Amjad!
You can find our repair guides here for fixing or replacing the buttons on this controller:
Reemplazo de los botones del DualShock 4
We also sell replacement parts for the controller if you need them. These are the buttons:
DualShock 4 Controller Action Button Covers
Imagen de Includes the plastic action button covers and the button gasket
Producto
Fue útil esta respuesta?
Puntuación 3
Make sure to clean the connection to from the conductive film to the motherboard.
https://youtu.be/Lx3La8a169Q
Puntuación 2
Thanks on the bottom of the phones keyboard, the square button doesn't work. How do I get it back working?
Puntuación 1
1 comentario:
How to make this work
- de
I was having issues with my left analog stick constantly drifting. Took the controller apart and cleaned it. Now it works great……except the square button doesn't work now. I'm thinking it's the clear film. May have a tear but I can't tell. Hope that info helps someone. Still working on my square button. Thinking about buying another mother board.
Puntuación 1
1 comentario:
I did same thing as Jason above, took controller apart cleaned it thoroughly put back together and square button not working.
- de
Exact same thing happened to me cleaned joysticks sensors and now square button doesn’t respond, I can see and feel it makes contact but no response I was thinking it was the ribbon strip because a couple of connections on the ribbon were folded back from disconnecting and reconnecting so many times maybe this could be the issue?
Puntuación 0
Añadir tu respuesta
Amjad Badkook estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 21
Ultimos 30 días: 77
Todo El Tiempo: 86,582
