iPhone is getting hot on the face of the screen.
Had replaced a screen on an iphone 6+ but the screen surface gets warm/hot when used. I replaced a proximity sensor, checked the heat shield to make sure the flex cable tab was properly placed underneath it. Any experience/suggestions would be appreciated.
Es esta una buena pregunta?
5 comentarios
Thank you. I will double check connectors
- de steve
The phone also loses battery power faster if that helps w diagnosis. Otherwise screen works and displays fine
- de steve
If the screen is still hot, then there is excess current draw which would deplete your battery faster.
- de Minho
How do I resolve this issue?
- de steve
It's probably the front facing camera ribbon cable assembly being at fault. Unplug it and then turn on the phone again to see if it still heats up during use. If not replace it.
- de Ben
