Saltar al contenido principal
Repair guides and support for budget electronics manufacturer Tagital.
Why wont my tablet turn on
it wont charge wunt turn on
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
Ann Shipman, There could be a few reasons for your device not charging and powering on. Faulty charger/cable, faulty battery, faulty charge port/connection etc., you could try a factory reset as described in 1st link below. Other links may help in trouble shooting your device if reset does not work. Good luck.
http://www.femitechservices.com/2016/04/...
https://www.youtube.com/watch?v=DSGAHFsn...
Tagital T7X Troubleshooting
Tagital T9X Battery Replacement
Tagital T7X Battery Replacement
Imagen de Tagital T7X Battery
Guía
Dificultad:
Difícil
5 - 10 minutes
Imagen de Tagital T9X Battery
Guía
Dificultad:
Difícil
25 minutes
Fue útil esta respuesta?
Puntuación 2
I'd suggest opening up the device and making sure that everything is appropriately Connected to your logic board. if not then find the plug and re connect the cable to the device. If you see nothing wrong with that, see if the charging port is loose, as this is common in low budget devices. If you see nothing wrong with that then I'm sorry, But your tablet had its run.
Puntuación 0
Añadir tu respuesta
Ann Shipman estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 835
