Saltar al contenido principal
Información de reparación del controlador de Nintendo 64, número de modelo NUS-005. Este controlador se lanzó en 1996 para usarse con la consola de juegos Nintendo 64.
Preguntas 9 Ver todo
Analog stick - Nintendo 64 Controller
Hi all,
My analog stick of mine controller is not working fine anymore. I found replacements on the internet. I found 2 different version.
I got version A in my controller. Can I solder version B in my controller?
Thanks in advance.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
From a bit of quick research, it appears that it should work fine. Just make sure that your pin connectors line up. Beyond that, it looks like it'll be okay to swap them out.
Best practice would be to install the new thumbstick and before closing it up, test out the controller to ensure that the new thumbstick reacts properly to the game.
Fue útil esta respuesta?
Puntuación 0
I'd say it's a bit risky to add one of those into your controller, because if you got a warranty for it (IF YOU ONLY GOT IT A SHORT WHILE AGO that is) you have to hack into your controller to install the analog stick, and opening it up usually voids the warranty. Also, I've heard that the replacement analog sticks aren't exactly the best. Look in the video below
https://www.youtube.com/watch?v=o3GYtAyR...
Puntuación 0
Añadir tu respuesta
Uas estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 710
