Driver for Windows 10?
Is a driver available for Windows 10.2?
Es esta una buena pregunta?
The HP PSC 2410 All-In-One is just that – it is a fax machine, scanner, printer, and copier. It was released in August of 2003 by Hewlett Packard.
Rep: 1
Hi,
HP ended driver support for your printer with Windows Vista.
You could try installing the Vista drivers in Windows 10 using Compatibilty mode and see if that works.
When you have the Vista driver software ready to be installed right click on the setup file and select Compatibility mode and then select either Vista (if available) or Win 7 and follow the prompts. See if it works after the install is complete.
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 18
Todo El Tiempo: 1,291
