Why does my phone always feel hot?
My phone is warm all the time and the more I use it the hotter it gets, it starts to get hotter once I turn it on from being completely off.
Es esta una buena pregunta?
First check your phone case, is it blocking your phone from ventilating? You may need to clean the lint and debris from the case so your phone can breathe. If you are using a case that was not made for your phone, that could be your issue.
It may also be your software. Too many applications open at the same time will overheat the phone and drain the battery. Close the applications that cause the most battery drain like your GPS. Turning down your screen brightness can help as well. If you are unsure how to check your software and battery for issues, check out the LG G2 Sprint troubleshooting page(link below) for some great tips!
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 298
