Where can I order Beats Pill 2.0 battery?
Hi! I'm having problems with my beats pill 2.0.
It only turns on when connected to a charger.
Where can I order its Battery? Is it the same as the beats pill 1.0?
Thank you so much!
Es esta una buena pregunta?
1 comentario
The battery for Beats Pill 2.0 is different from Beats Pill 1.0 battery.
Pill 1.0 battery is made of two 092941 batteries in Parallel, without Fuel Gauge IC, the capacity is 1050 * 2 = 2100mAh, the nominal voltage is 3.7V;
Pill 2.0 battery is made of two 092941 batteries in Series, with Fuel Gauge IC, capacity 1050mAh, the nominal voltage is 7.4V.
- de Jailene
