Why does it say card full
Card is formatted and empty. Can take only 3 pictures before it says card is full. How do I delete internal memory?
Es esta una buena pregunta?
Puntuación
0
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 596
Hi,
What capacity is the external SD Card that you are using?
Have you tried using a different SD card to check if yours is faulty.
Did you format the SD card in the camera?
- de jayeff
Capacity is 32. Yes, I tried different SD cards. Yes, I did format the SD card in the camera. Still same problem.
- de May
Hi, Have you tried to manually reset 'File Numbering' in the settings area. Just a thought.
- de jayeff
