Why doesn't my computer have sound?
Es esta una buena pregunta?
A couple of things could lead to this. First, check to see if you have muted the computer. If this is not the case, then check to see that you have no external sound devices hooked up to the computer. If still nothing is found and no sound is playing, try to update the drivers for the sound card, or re-install/ find another comparable sound driver. If still nothing has worked, than you need to try to replace the sound card.
Fue útil esta respuesta?
Hi Erin,
FYI. Not too many laptops, if any, have separate 'sound cards'. The audio controller is built into the motherboard. If the problem is on the motherboard it is easier to buy a USB sound card adapter than to either try and fix the motherboard (hard) or replace it (expensive), if you want to have sound and keep the laptop.
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 9
Todo El Tiempo: 130
