Saltar al contenido principal
La Nikon D5200 es una cámara DSLR con montura F y un sensor de imagen CMOS de formato DX de 24,1 megapíxeles. La D5200 tiene una resolución máxima de 6000x4000 y es capaz de grabar videos de 1080p.
Preguntas 30 Ver todo
LCD on but not showing a picture
My D5200 seems to be working just fine other than the fact that it is not showing an picture on the LCD screen. The screen stays grey when turned on but will not show anything (regardless of if I mess with the buttons). I can still take photos and retrieve them from the SD card.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
1 comentario
I have tried hard resets and taking the battery out for 24 hours, no luck.
- de
Agregar un comentario
2 Respuestas
Respuesta Más Útil
sounds like you need a new LCD, follow this guide to fitting a new one
Nikon D5200 Screen Replacement
Fue útil esta respuesta?
Puntuación 1
1 comentario:
Hi @jackattack101 ,
To add to @rayeasom's answer, the LCD screen is available on places like Ebay. Here is a link to one supplier. This is not a recommendation, it is merely shown to give you an idea of the cost of the part. http://www.ebay.com/itm/NEW-LCD-Display-...
- de
I had the same problem sent it away to Nikon who couldn’t fault itso,
remove the four lcd retaining screws so you can get in and behind the screen there you will find a small electrical connector ( silver in colour and slides onto the circuit board and clips into place)and a larger connectorI found that the larger connector purely by chance wasn’t located and clipped securely in placeyou’ll see what I mean once it’s opened up…
resecured and everything worked as it should reattached lcd screen ,,,never had an issue since
Puntuación 0
Añadir tu respuesta
Jack estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 765
