Is there a way to make my battery last longer?
I've been using the device for a while, and it seems over time that the battery life has been significantly diminished. Is there anyway to help or fix this problem?
Es esta una buena pregunta?
Hey Brennan,
Great question! I think we all could use a longer battery life for all our devices! There ARE a few tricks you can try.
- Free up some RAM by closing out of apps when you're not using them
- Turn brightness down whenever possible; the backlight is a major drain of battery life
- Turn off bluetooth and wifi whenever possible
- Limit notifications
If none of these seem to do the trick, it may be time for a new battery. Head over to our battery replacement guide to get started.
Best of luck!
Fue útil esta respuesta?
Brennan, did you just post and answer you own question???
@lpfaff1 Remember, I told you to watch out for questions like this. Check the OP - student
mayer, yes you did,thanks :-{(
Hey Brennan,
If none of these seem to do the trick, it may be time for a new battery. Head over to our Battery replacement guide to get started.
Best of luck!
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 215
