Introducción
Before beginning, be absolutely sure the battery needs replacing. The HP Stream 7's battery is taped to the display panel and it is highly likely the battery will be damaged during removal. Everything else should come off with little force: do not try to muscle components free.
Qué necesitas
Make sure the tablet is powered off before beginning.
Gently run the plastic opening tool or your fingernails around the tablet to pry the Back Cover from the tablet.
3 personas más completaron esta guía.
