Why do warning lights stay on when engine is running
why do warning lights on dash stay on when engine is running
Es esta una buena pregunta?
Norman, see the attached links for various warning lights and why they may be on. In some makes a lot of warning lights may come on and stay on when battery is faulty or charging system fault if both are tested and found to be good, you will have to have a good technician have a look, diagnose and estimate repair. Cluster or PCM could be faulty and not communicating correctly to one another. Check the attached links,instruction and guides, Good luck.
http://www.autozone.com/landing/page.jsp...
Fue útil esta respuesta?
Last week I am visiting at http://universalmotorcarslv.com/ they guest are best
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 26
Todo El Tiempo: 926
Hi, Which warning lights are staying on?
- de jayeff
