Saltar al contenido principal
Portable Bluetooth speaker released in June 2015. The speaker features ClearAudio+ Technology and LDAC Technology. Model Number: SRS-X55.
Preguntas 11 Ver todo
Why is the sound skipping on my speakers?
Hi!
I've had my SRS-X55 for about four months now and it's been working like a dream. But in the last few weeks, when it's connected to my Macbook via Bluetooth, I've been having a problem where the sound skips/cuts out for a second about once every four to five seconds.
The sound is fine when I connect the speakers to my phone and the problem doesn't seem to be associated with just one program either.
I've tried unpairing and reconnecting, as well as a soft reset of my speaker. Is there anything else I can do?
Thanks!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
1 comentario:
Hi, Just wondering if you could try connecting your Macbook to another BT speaker and see if it happens as well, to prove if the problem is with the computer or not as you say that it is alright when you pair the speaker with a phone.
Is there any difference regarding location or distance etc of speaker/Macbook than from before when it worked OK? Just wondering whether the Macbook or its' power adapter etc is causing interference to the BT signal. When you try the speaker/phone setup is it in the same location as the Macbook /speaker setup?
- de
Agregar un comentario
1 Respuesta
I have the same issue from my mac with the SRS-XB30.. Was there ever a resolution for this?
Fue útil esta respuesta?
Puntuación 0
1 comentario:
I also have a SRS-XB30 that has suddenly started skipping. I've tried through multiple devices and it seems to be the speaker that is malfunctioning. It seems to work better when the speaker is pointing up which makes me think something on the inside may be loose. Any thoughts?
- de
Añadir tu respuesta
fra09sam estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 18
Todo El Tiempo: 1,929
