My drill will not turn on?
I have tried charging the battery in multiple outlets and it still will not turn on.
Es esta una buena pregunta?
Have you checked to make sure the battery clicks when you put it on the charger or into the drill, or looked for corrosion on the battery ports? Check to see if the charger light turns on when you plug it in, if not you might need to replace your charger. If your light turns on and the battery clicks in but it still won't turn on, you may need to replace your battery.
Here's a link for a new battery if you need it.
Here's the link to our troubleshooting page if you need any more help!
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 14
Todo El Tiempo: 1,639
