Not firing when trying to crank
My power washer does fire when I try and crank it
Es esta una buena pregunta?
gail, trouble shooting pressure washer small engine will not fire. You will have to test the engine for fuel/air/spark/compression and see what is missing/faulty. Check the attached links,instruction and guides, Good luck
http://www.repairfaq.org/samnew/lmfaq/lm...
https://www.briggsandstratton.com/na/en_...
http://www.jackssmallengines.com/diy/tro...
Fue útil esta respuesta?
Check Sparkplugs for loose wire, dirty connection, or debris. Spark plugs on small equipment can also break pretty easily since they are exposed.
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 7
Todo El Tiempo: 133
1 comentario
gailfeltman what make and model is it? What do you mean by "washer does fire when I try and crank it"? It fires up? It comes on fire?
- de oldturkey03
