Water in my lap
How i can fix my laptop?
My laptop is stop working because the water inside and the screen is black i can do eny things plz help me
Es esta una buena pregunta?
Hi,
As you know water and electronics and electricity are not a good mix.
The water causes corrosion and provides circuit paths for the electricity which were not in the laptop's operating design and could damage the components.
First you need to remove the battery as soon as possible from the laptop
Then you need to dis-assemble the laptop and clean all the affected parts using Isopropyl Alcohol 90%+ to remove all traces of corrosion and water.
Here is a link that in general, describes the process.
You will probably have to replace the battery as it is very hard to recover a battery from water damage.
Here is a link that shows how to dis-assemble your laptop.
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the laptop might possibly work correctly again
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 121
