Prints and Copies are coming out with jagged lines/texts
My prints and copies are coming out with jagged lines/texts
Es esta una buena pregunta?
Hi,
Perform a print alignment check of your printer.
Here is an image that shows what to do.
Fue útil esta respuesta?
You should run the cleaning cycle a few times I had an issue that there was lines and magenta wasn’t coming out the print head is just clogged
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 22
Todo El Tiempo: 4,428
3 comentarios
Thanks for your response Jayeff. However, I did try this several times but it made no difference.
- de Khemchand Ramcharan
Re-aligning print heads doesn't solve the problem....
- de Tracy Lloyd
Hi @ Tracy Lloyd,
Try cleaning the paper transport rollers in case they are causing the paper to stick and not feed through smoothly
- de jayeff
