Saltar al contenido principal
The metal pin from the power cord broke-off in the female plug
The metal pin from the power cord broke-off in the female plug and when I plug it in it causes a spark. I need to remove the female mechanism to try and push it out from the rear of the mechanism
Es esta una buena pregunta?
Puntuación 0
1 comentario
This question has already been asked many different times. Please check through those answers and try the solutions.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
The part it's in is called the DC IN port. Once this is removed the center bracket on the back of the unit can sometimes be pulled slightly out and the tip removed. If this cannot be done, it's a fairly simple procedure to replace it.
Here's the part: [producto vinculado inexistente o deshabilitado: IF153-021]
Or here: http://www.encompassparts.com/products/?...
Here's how to replace it: PowerBook G4 Aluminum 12" 1-1.5 GHz DC-In Board Replacement
Fue útil esta respuesta?
Puntuación 2
1 comentario:
Good answer +
- de
Añadir tu respuesta
jeff estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 3,327
