Engine will not turn over
After replacing my fuel pump, my vehicle started up. But then the next day nothing. Did not turn over. When i attempt to start it i get a clicking sound.
Es esta una buena pregunta?
Hi,
Have you checked your battery cables are securely connected and that the battery is not flat?
Usually a clicking sound is the starter solenoid engaging but there is not enough power for the starter motor to turn over.
Fue útil esta respuesta?
You either have a bad starter,battery or alternator. Or you just have a bad ground on your fuel pump ground.
Try jumping the car and or tapping the starter with a hammer
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 21
Todo El Tiempo: 490
